Bob94301
Sep 24, 2016Guide
C7000-100NAS no longer emails logs
Hi folks, Just started no longer sending logs. Worked fine for quite some time. Error message is: [email failed] Failed to Connect Tcp Socket! 360 I am guessing that my email provider cha...
Bob94301
Sep 24, 2016Guide
This does seem to be the case. The router is hard coded to use Port 25 and virtually no providers allow that any longer. Hard to believe this has not been addressed. Also hard to belive that I need to pay to talk to Netgear about this? I bought this in January and support ended in March? And now I have no ability for emailed logs and no idea when or if ever there will be updated firmware. Not excited how how Netgear addresses their customer base. Will definitely take all this into consideration on future purchases.
Appreciate if anyone has a solution to the port 25 issue....
~Bob
DarrenM
Sep 27, 2016Sr. NETGEAR Moderator
Hello Bob 94301
If your ISP is blocking port 25 not much we can do to change that I read they block that port so spam emails are not sent across there Ip address.
DarrenM
