sheeniz
Jan 21, 2020Aspirant
C7000-100NAS Slower WiFi speed vs wired connection
Have C7000-100NAS on Comcast with a 500Mbps plan, have never got the speed of more than 200-250Mbps on any of my devices and all of them are connected wirelessly. While troubleshooting with Comcast s...
michaelkenward
Jan 22, 2020Guru - Experienced User
You don't say what your wifi clients are, but that may be as fast as they can manage.
Are they a lot faster when you use them with other wifi sources?
How fast is your wired speed out of the router?
Your 500 Mbps determines the speed of wired stuff, not wifi.
This page from duckware may be useful:
sheeniz
Jan 22, 2020Aspirant
Thanks for the answer and specially for the link it has some great details.
Client devices I have tried with Mac, iPhone11 and iPadPro.
- michaelkenwardJan 22, 2020Guru - Experienced User
- labattJan 22, 2020Mentor
Agree a iPhone 11 should do better. I have a 1 gig plan and my iPhone 10 gets 451Mbs down and 43.6Mbs up currently. ISP is Comcast. So would figure that on a 500 plan should pretty much max as long as the iPhone is only device creating traffic.
- FURRYe38Jan 22, 2020Guru - Experienced User
AC1900 (600 Mbps @2.4GHz with 256 QAM support +1300 Mbps 5Ghz 11ac)†
• Simultaneous Dual Band WiFi—Tx/Rx 3x3 (2.4GHz) + 3x3 (5GHz)†
Maximum wireless signal rate derived from IEEE standard 802.11 specifications. Actual data throughput and wireless coverage will vary.Use WiFi SweetSpots app on your devices to see the connection rate beween the device and the modem.
labatt wrote:Agree a iPhone 11 should do better. I have a 1 gig plan and my iPhone 10 gets 451Mbs down and 43.6Mbs up currently. ISP is Comcast. So would figure that on a 500 plan should pretty much max as long as the iPhone is only device creating traffic.
