sheeniz
Jan 21, 2020Aspirant
C7000-100NAS Slower WiFi speed vs wired connection
Have C7000-100NAS on Comcast with a 500Mbps plan, have never got the speed of more than 200-250Mbps on any of my devices and all of them are connected wirelessly. While troubleshooting with Comcast s...
sheeniz
Jan 24, 2020Aspirant
Still not able to figure it out
Wifi SweetSpot shows the same 200Mbps
Wifi configuration show TX rate of 1+ Mbps
https://ibb.co/HHQNJ9w
Confimed using another Wifi network and number seems to match the speed I was getting on that network:
https://ibb.co/sv02MRN
- sheenizJan 25, 2020Aspirant
Tried this morning and seem to be getting 284Mbps, not sure what is stopping the router to give maximum speed.
- FURRYe38Jan 25, 2020Guru - Experienced User
So the connection rate between your wireless device and the modem is around only 200Mbps, This is limiting seeing any faster speeds when speed testing. So your wireless device is only connecting at 200Mpbs or possible the modem could be faulty. Does the modem show which frequency the device is connecting at? 2.4 or 5Ghz? Seems like only 2.4Ghz.
- sheenizJan 26, 2020Aspirant
Wifi is configured for 5GHz and router shows the devices connected to the same frequency.
