cbwatts1957
Aug 24, 2015Aspirant
C7000-100NAS
I got no internet connection. | ||||||||
| System Delegated Prefix 2601:203:201:2590::/60 | ||||||||
| IP Address Assignment | ||||||||
| Use DHCP Server | ||||||||
| Auto Config | ||||||||
| Disable IPv6 Firewall Protection | ||||||||
- DarrenMSr. NETGEAR Moderator
Hello Cbwatts1957
I need some more info about not having a Internet connection. Have you called your cable company and made sure they have properly added your modem to your account and see if they are able to ping the modem and that it is getting a ip address from them?
DarrenM
- cbwatts1957Aspirant
Yes, found out comcast in put model number, i took the other one back an got new on, the new is running good every thing work.
Thank You
