KBottle
Mar 15, 2018Aspirant
C7000 AC1900 Router
Router stopped working, all the lights are on, no change when I in plug it for a few minutes. Also no change when I hold on the reset button. It's basically frozen. Any ideas on what's wrong with it?
KBottle
We noticed it this afternoon. All of the indicator lights are solid green and the power indicator is a solid red. The indicator lights remain lit even after trying to do a factory reset. To my knowledge the firmware was never updated. There was also a power outage someone today, but the router was on a surge protected strip so I think that was a coincidence.
William10a
Mar 15, 2018Master
A surge protected strip will not stop the power from just stopping reaching the modem/router depending on how long was off and the way the power came back on the firmware could having a problem or it may need a reset from the isp from their end to reset the modem. You would need a ups power supply to keep the modem running without the mains power. One more thing to try disconnect the power from the modem let sit for around four or five minutes and reapply power to the modem too see if it unlocks and comes back to life.
- michaelkenwardMar 16, 2018Guru - Experienced User
Remember, the C7000 is a cable modem-router rather than a plain router. This means that firmware is in the hands of your Internet service provider.
I assume that the ISP has told you that the Internet is still working.
