helpme2
Mar 31, 2016Aspirant
c7000 and s6 active wifi
the wifi on my s6 active when connected to 2.4 or 5.0Ghz is extremely slow. strong signals, tried changing channels and nothing. wmm is enabled, Have done just about everything I could find to fix the s6, rebooting, forgetting network and connecting, resetting router/modem, factory reset phone and c7000, static ip, etc. you name it. when i first loaded up the modem/router, wifi worked great and fast, but now it takes minutes to load anything on the phone when connected by wifi. when I connect to any other wifi network, everything loads no problem which leads me to believe it has to be the nighthawk. when i load up ipv6-test.com connected by wifi, nothing is supported. when i run it off the lte network, everything is good. no idea what ipv4-6 is or does when you start getting technical into that direction. firmware is up to date and phone software is current, lollipop 5.1.1. any ideas or suggestions would be much appreciated. thanks
- DarrenMSr. NETGEAR Moderator
Hello Helpme2
Have you tried to disable WMM?
DarrenM
- helpme2Aspirant
I have disabled WMM on both 2.4 and 5GHz. reset router and s6 and still no luck.
- helpme2Aspirant
using the netgear genie app for the computer, it shows the link rate between the s6 and and network as 24Mbps. the samsung tv i have connected to the network shows 866Mbps. the tv is connected to the 5Ghz. When I connect the s6 to the 5Ghz the link speed is 866Mbps as well, however the load times on apps like reddit or facebook or the google homepage on the internet browser are extremely slow. about 1 to 2 minutes to load if that, sometimes pictures or whatever is on facebook will not load. just tested again on a free wireless network at a mall today and wifi loaded everything no problem.
Hello helpme2
I know that other people have been having issues with Samsung S6 and S7 phones on wifi our engineers are aware of it and have been trying to pinpoint the issues to find a fix. i will let everyone know if I hear more on what the issues are.
DarrenM
