Fredo8454's avatar
May 25, 2023
C7000 as Wifi router
Hi, I would like to know if it's possible to use the C7000 3.0 as a Wifi router only since I got the new Spectrum modem 3.1 and how to do it?   Thank you
  • plemans's avatar
    May 26, 2023
    what speeds do you pay for?
    Might not need anything as it should still hit 600-800mbps on spectrum. the C7000 has a pretty solid modem and it might just be spectrum pushing you to upgrade.
