Fredo8454
May 25, 2023Tutor
C7000 as Wifi router
Hi, I would like to know if it's possible to use the C7000 3.0 as a Wifi router only since I got the new Spectrum modem 3.1 and how to do it? Thank you
- May 26, 2023
what speeds do you pay for?
Might not need anything as it should still hit 600-800mbps on spectrum. the C7000 has a pretty solid modem and it might just be spectrum pushing you to upgrade.
Fredo8454
May 26, 2023Tutor
I wasn't aware of that at all, thanks.
So I will look for a router and use the Spectrum modem I guess.
May 26, 2023Guru - Experienced User
Can do that or ask the ISP which NG CM series modem is supported by them and you could connect it. If you wanted to avoid any rental fees from the ISP.
Good Luck.
- Fredo8454May 26, 2023Tutor
I asked Spectrum and the guy told me that the modem is for free but I could rent them the router. I'm sceptical since it's written "leased" on the modem box...
