andreah1
Nov 28, 2019Apprentice
C7000 Blinking Downstream? Choppy Internet
Hoping someone can help? My c7000 has a constant blinking green downstream light? At times both the upstream and downstream are a solid amber (not often). I've rebooted it numerous times both by p...
andreah1
Nov 30, 2019Apprentice
Anyone? Was hoping for some guidance, seems 18 months would be WAY too quick for a router to die? I can provide any info needed, just let me know. Thanks.
- andreah1Dec 01, 2019Apprentice
Just a little more information in hopes it will help with a reply. I have a netgear c3700 that the c7000 replaced. I just hooked that one up and disconnected the c7000. The c3700 had both upstream and downstream lights blinking green and my desktop would connect with it but it said "no internet". When I plugged the c7000 in it went right back to the blinking upstream but I do have internet.
I have checked all connections and can't find anything, spectrum says nothing on their end. I'm at a loss, can anyone please give me a hand? THANKS!
And yet another update - I went to the splitter and disconnected it, hooked up the c3700 to the direct line and it was fine, no blinking lights. I then hooked up with c7000 and still have the blinking downstream. Is that a router issue?
