Spantanswill
Apr 13, 2020Aspirant
C7000 bridged with r7800 problems renewing isp dhcp
Keep getting log below from the c7000 modem with t3 and t4 disconnects. Any thoughts on this? Dhcp on r7800 set to use computer mac address. Error (4) DHCP RENEW WARNING - Field invalid in response v...
Apr 13, 2020Guru - Experienced User
Please take a screen snip of your cable connections page and your logs.
get all the info off the connections page as this shows the upstream/downstream connection to your isp.
Spantanswill
Here's what I've got.
- plemansApr 13, 2020Guru - Experienced User
and the cable connection page?
should look similar to the one i attached.
- SpantanswillApr 13, 2020AspirantThought i got both
You're downstream power levels are a little on the high side and your upstream is on the low side. upstream you usually want 35dbmv and you're right there but if the signal drops, you'd be low. And you've a few errors in your signal but nothing crazy.
Here's where I'd start.
If there's any amplifiers, attenuators, splitters in the coax line, remove them. Use it for a while and see how it runs. And then run this same screen shot again.
