Spantanswill
Apr 13, 2020Aspirant
C7000 bridged with r7800 problems renewing isp dhcp
Keep getting log below from the c7000 modem with t3 and t4 disconnects. Any thoughts on this? Dhcp on r7800 set to use computer mac address. Error (4) DHCP RENEW WARNING - Field invalid in response v...
Spantanswill
Here's what I've got.
Apr 13, 2020Guru - Experienced User
and the cable connection page?
should look similar to the one i attached.
- SpantanswillApr 13, 2020AspirantThought i got both
- plemansApr 13, 2020Guru - Experienced User
You're downstream power levels are a little on the high side and your upstream is on the low side. upstream you usually want 35dbmv and you're right there but if the signal drops, you'd be low. And you've a few errors in your signal but nothing crazy.
Here's where I'd start.
If there's any amplifiers, attenuators, splitters in the coax line, remove them. Use it for a while and see how it runs. And then run this same screen shot again.
- SpantanswillApr 13, 2020AspirantIt was connected on a splitter in the past and was having the same problem but currently connected directly to the wow line that comes through the wall.
