Techbud's avatar
Techbud
Follower
Mar 22, 2020
c7000 cable modem no longer connects to wired devices but does to wireless devices
C1700 AC1900 WIFI Cable Modem Router,  Firmware 1.01.33,  ISP  Comcast in CA:
No change was made to the router but something very strange is happening today (sunday) .  Only wireless connections are working.  No hardwire connected devices are getting connectivity except for 1, my Lutron lights.  Both the 2.4 and 5 wireless networks are working .  Very strange as everything was working fine on Fri and Sat and then on Sun it just stopped and I have rebooted the router many times and doesn't seem to fix it.  I have also have tried to turn on access control and all of the wired devices show up as "allowed devices but not connected"  Due to the Corona virus I can't get through to support.     All the lights are blinking on the ethernet cables on the source and devices and I have tried powercycling those as well. Disconnecting and reconnectig the cables.    I do see a couple not all hard wire connections show up on the UI once I boot up my router but then within a minute, they disappear except for the lights.  Can somone let me know what what else I should try?  I have room for 24 devices and ony 12 are connected.   This is very strange.  Can you also let me know if I do a factory reset, do I have to go through the long and tedius phone call with Comcast and does it go back in firmware version which then I do probably have to call comcast to get the firmware upgraded again?
1 Reply
  • > Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
       Is that accurate?  Not a C7000v2?  Look at the product label.
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.  Read.  Look for the
    LED descriptions and "Troubleshoot".
    > [...] Only wireless connections are working. [...]
       Which kind of "not working" is this?  "not working" is not a useful
    problem description.  It does not say what you did. It does not say
    what happened when you did it.  As usual, showing actual actions
    (commands) with their actual results (error messages, LED indicators,
    ...) can be more helpful than vague descriptions or interpretations.
    > [...] No hardwire connected devices are getting connectivity [...]
       Regarding "not getting connectivity", see "not a useful problem
    description [...]", above.
       What are your (unspecified) "hardwire connected devices"?  How many?
    Connected directly to the C7000 LAN Ethernet ports?  Is any of them a
    computer with a user-interface where you might be able to get some
    information from it about its network connection?
    > [...] All the lights are blinking on the ethernet cables [...]
       _Which_ "the lights", where?  At the LAN Ethernet ports on the C7000?
    Color(s)?  "blinking" variably, showing activity?
    > [...] I do see a couple not all hard wire connections show up on the
    > UI [...]
       _Where_ "on the UI"?  Attached Devices report, or what?
    > [...] I have room for 24 devices and ony 12 are connected. [...]
       I've never touched a C7000, so I know nothing, but when I look at the
    pictures in the C7000 User Manual, I see only four LAN Ethernet ports.
    Perhaps a more accurate equipment inventory, and a better description of
    exactly what's connected to what would be helpful.  A bad cable between
    your C7000 and your (apparent, unmentioned, unspecified) 24-port network
    hub/switch (or some problem with that device) might explain many
    potential problems.
       One obvious diagnostic step would be to connect a device (or more)
    directly to the C7000, and see what happens.
    > [...] I do a factory reset, do I have to go through the long and
    > tedius phone call with Comcast [...]
       I don't see why you would.  If they liked it before (and if you
    didn't fiddle with any MAC addresses), then they should still like it
    after a settings reset.
    > [...] and does it go back in firmware version [...]
       I wouldn't expect that.
