bocaallupo
Jan 07, 2020Aspirant
C7000 Continuously Slow Internet
I have the Comcast 175Mbps package. I have had my Nighthawk for a few years and it has always had an issue where the internet speed would slow down to around 10. If I reset my router by unplugging/pl...
vkdelta
Jan 09, 2020NETGEAR Employee Retired
Please provide Cable Connection page screenshots and Event log screenshots after you have run some traffic and you have noticied slowdowns.
- bocaallupoJan 10, 2020Aspirant
I see it has slowed down to 50Mbps. Here are the logs.
Description Count Last Occurrence Target Source [admin login] from source 192.168.0.10 1 Fri Jan 10 16:16:52 2020 0.0.0.0:0 192.168.0.10:0 [ login failure] from source 192.168.0.10 1 Fri Jan 10 16:16:46 2020 0.0.0.0:0 192.168.0.10:0 [DHCP IP: 192.168.0.12] to MAC address 28:18:78:ef:d1:8b 1 Fri Jan 10 07:11:46 2020 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.10] to MAC address d8:6c:63:d6:2e:ab 1 Fri Jan 10 07:11:33 2020 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.12] to MAC address 28:18:78:ef:d1:8b 1 Fri Jan 10 07:11:24 2020 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.10] to MAC address d8:6c:63:d6:2e:ab 1 Fri Jan 10 07:11:22 2020 0.0.0.0:0 0.0.0.0:0 [Internet connected] IP address: 73.34.110.248 1 Fri Jan 10 07:11:18 2020 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.10] to MAC address d8:6c:63:d6:2e:ab 1 Fri Jan 10 07:11:11 2020 0.0.0.0:0 0.0.0.0:0 [Time synchronized with ToD server] 1 Fri Jan 10 07:11:08 2020 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.10] to MAC address d8:6c:63:d6:2e:ab 1 Thu Jan 01 00:00:53 1970 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.10] to MAC address d8:6c:63:d6:2e:ab 1 Thu Jan 01 00:00:51 1970 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.12] to MAC address 28:18:78:ef:d1:8b 1 Thu Jan 01 00:00:39 1970 0.0.0.0:0 0.0.0.0:0 [DHCP IP: 192.168.0.11] to MAC address 00:18:4d:ff:ff:07 1 Thu Jan 01 00:00:39 1970 0.0.0.0:0 0.0.0.0:0 - bocaallupoJan 10, 2020Aspirant
I am connected directly to the cable coming into the house. I have made sure the connection is tight and the internal wire is straight and lining up when I connect it to the modem. It seems weird it would be a connection issue when everything starts working as it should after a power reset.
- plemansJan 11, 2020Guru - Experienced User
bocaallupo wrote:I am connected directly to the cable coming into the house. I have made sure the connection is tight and the internal wire is straight and lining up when I connect it to the modem. It seems weird it would be a connection issue when everything starts working as it should after a power reset.
Which is all good but how do we know its working good without seeing some actual data from the connections page and the logs page?
