bocaallupo
Jan 07, 2020Aspirant
C7000 Continuously Slow Internet
I have the Comcast 175Mbps package. I have had my Nighthawk for a few years and it has always had an issue where the internet speed would slow down to around 10. If I reset my router by unplugging/pl...
vkdelta
Jan 09, 2020NETGEAR Employee Retired
Please provide Cable Connection page screenshots and Event log screenshots after you have run some traffic and you have noticied slowdowns.
bocaallupo
Jan 10, 2020Aspirant
I am connected directly to the cable coming into the house. I have made sure the connection is tight and the internal wire is straight and lining up when I connect it to the modem. It seems weird it would be a connection issue when everything starts working as it should after a power reset.
- plemansJan 11, 2020Guru - Experienced User
bocaallupo wrote:I am connected directly to the cable coming into the house. I have made sure the connection is tight and the internal wire is straight and lining up when I connect it to the modem. It seems weird it would be a connection issue when everything starts working as it should after a power reset.
Which is all good but how do we know its working good without seeing some actual data from the connections page and the logs page?
