bocaallupo
Jan 07, 2020Aspirant
C7000 Continuously Slow Internet
I have the Comcast 175Mbps package. I have had my Nighthawk for a few years and it has always had an issue where the internet speed would slow down to around 10. If I reset my router by unplugging/pl...
bocaallupo
Jan 10, 2020Aspirant
I am connected directly to the cable coming into the house. I have made sure the connection is tight and the internal wire is straight and lining up when I connect it to the modem. It seems weird it would be a connection issue when everything starts working as it should after a power reset.
Jan 11, 2020Guru - Experienced User
bocaallupo wrote:I am connected directly to the cable coming into the house. I have made sure the connection is tight and the internal wire is straight and lining up when I connect it to the modem. It seems weird it would be a connection issue when everything starts working as it should after a power reset.
Which is all good but how do we know its working good without seeing some actual data from the connections page and the logs page?
