jk320
Dec 01, 2020Aspirant
c7000 dropping wifi
My modem/router is frequently unable to get internet/wifi signal to random things in the house. Sometimes its my computer, other times fire TV, etc. This is happening more frequently than ever. Usual...
Dec 02, 2020Guru - Experienced User
do you have a screen snip of the cable connections page and the logs?
That lets us check the signal from the isp.
Have you noticed if its mainly device on 2.4gh? 5ghz? wired devices?
- jk320Dec 02, 2020Aspirant
I notice the 5ghz signal only becauase my smart TVs are on it. My computer is also usually on 5ghz which I notice the most.
Startup Procedure Procedure Status Comment Acquire Downstream Channel 537000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 17 537000000 Hz 3.4 dBmV 39.3 dB 0 0 2 Locked QAM256 1 423000000 Hz 3.4 dBmV 39.4 dB 0 0 3 Locked QAM256 2 435000000 Hz 3.3 dBmV 38.9 dB 0 0 4 Locked QAM256 3 447000000 Hz 3.8 dBmV 39.3 dB 0 0 5 Locked QAM256 4 453000000 Hz 3.9 dBmV 39.5 dB 0 0 6 Locked QAM256 5 459000000 Hz 3.8 dBmV 39.5 dB 0 0 7 Locked QAM256 6 465000000 Hz 3.9 dBmV 39.7 dB 0 0 8 Locked QAM256 7 471000000 Hz 3.8 dBmV 39.8 dB 0 0 9 Locked QAM256 8 477000000 Hz 3.9 dBmV 39.9 dB 0 0 10 Locked QAM256 9 483000000 Hz 3.6 dBmV 39.8 dB 0 0 11 Locked QAM256 10 489000000 Hz 3.8 dBmV 39.8 dB 0 0 12 Locked QAM256 11 495000000 Hz 3.9 dBmV 39.6 dB 0 0 13 Locked QAM256 12 507000000 Hz 3.8 dBmV 38.8 dB 0 0 14 Locked QAM256 13 513000000 Hz 3.6 dBmV 39.2 dB 0 0 15 Locked QAM256 14 519000000 Hz 3.5 dBmV 39.1 dB 0 0 16 Locked QAM256 15 525000000 Hz 3.2 dBmV 38.8 dB 0 0 17 Locked QAM256 16 531000000 Hz 2.5 dBmV 38.8 dB 0 0 18 Locked QAM256 18 543000000 Hz 2.4 dBmV 39 dB 0 0 19 Locked QAM256 19 549000000 Hz 2.4 dBmV 39 dB 0 0 20 Locked QAM256 20 555000000 Hz 2.3 dBmV 39 dB 0 0 21 Locked QAM256 21 561000000 Hz 2.1 dBmV 39 dB 0 0 22 Locked QAM256 22 567000000 Hz 2.3 dBmV 39.4 dB 0 0 23 Locked QAM256 23 573000000 Hz 2.3 dBmV 39.1 dB 0 0 24 Locked QAM256 24 579000000 Hz 2.1 dBmV 39.1 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 4 5120 Ksym/sec 35700000 Hz 43.5 dBmV 2 Locked ATDMA 1 5120 Ksym/sec 16200000 Hz 43.5 dBmV 3 Locked ATDMA 2 5120 Ksym/sec 22700000 Hz 43.5 dBmV 4 Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 43.5 dBmV 5 Locked ATDMA 5 1280 Ksym/sec 41200000 Hz 43.5 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV - jk320Dec 02, 2020Aspirant
Time Priority Description 2020-12-2, 03:09:13 Warning (5) Dynamic Range Window violation 2020-12-2, 03:09:12 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:cc:fc:61:de:b1;CM-QOS=1.1;CM-VER=3.0; 2020-12-1, 23:08:43 Warning (5) Dynamic Range Window violation 1970-1-1, 00:00:50 Notice (6) Honoring MDD; IP provisioning mode = IPv6 1970-1-1, 00:00:40 Notice (6) WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:40 Notice (6) WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2020-11-29, 10:31:15 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:cc:fc:61:de:b1;CM-QOS=1.1;CM-VER=3.0; 1970-1-1, 00:21:47 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:21:43 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:21:43 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:21:35 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:21:34 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:21:28 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:21:13 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:21:12 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:21:04 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:21:02 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:18:56 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:18:53 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:18:35 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:18:33 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:16:27 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:16:27 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:16:26 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:16:24 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:16:04 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:16:02 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:13:55 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:13:55 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:13:55 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:13:53 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:13:33 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:13:31 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:11:26 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:11:24 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:11:04 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:11:02 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:08:55 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:08:55 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:01:03:b8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; - plemansDec 02, 2020Guru - Experienced User
Your power levels from the cable connections page looks spot on. But your getting power violations on the logs ant t3/t4 errors with sync errors. They tend to indicate line issues. Might be worth having the isp checking the line.
I'd also check to see if you have any splitters, amplifiers, or attenautors in line and remove them.
How frequently is it happening?
A reboot is the only thing that fixes it?
Do hardwired devices have issues when its happening?
