gagandeep's avatar
Aug 16, 2019
C7000 firmware downgrade
Is there a way I can get an older firmware and flash it? If yes where can I download from? Thank you
  • IrvSp's avatar
    Aug 16, 2019
    Wrong forum, should be in the Cable Modem Forum, go to COMMUNITY, select HOME, and then CABLE MODEM.
    As far as I know, ONLY your ISP can do that, they control the modem and f/w running on it.
