neatgear_psu
Dec 12, 2018Aspirant
C7000 Frequent Disconnects
Hi all,
After about 6 months of reliable internet, I've started receiving frequent T3 and T4 errors. Based on some internet searching, it looks like this problem is usually due to noise in the ...
DarrenM
Dec 14, 2018Sr. NETGEAR Moderator
This could be a issue of lines in your area you may need the ISP tech to come check things out.
DarrenM
- neatgear_psuDec 16, 2018Aspirant
Darren,
Thanks for the response. As you suggested, I had a tech come to my home to check things out. Based on his testing, he could not identify any issues with the the signal coming from the drop box, nor any issue with the cabling in my house. He did replace the lone splitter and all coax connections, stating bad coax connections can cause the symptoms I saw. Despite the troubleshooting efforts, I am still getting T3 and T4 timeouts with the same regularity as before. It seems to me that whatever is causing the issue is very transient in nature, and probably not associated with the lines on my property.
If I have the ISP send another tech back out, is there anything in particular I should ask them to investigate? The tech thought it was not likely an issue with my modem, but I'm considering leasing a modem through the ISP for one billing period to at least rule out the possibility.
- DarrenMDec 26, 2018Sr. NETGEAR Moderator
Kind of a hard issue to pin down could be issues down the line past what the tech checked out but yes you could try renting a modem for a month just to rule that out.
DarrenM
