damianinpa
Aug 09, 2017Guide
C7000 Iphone causing DOS attacks and drops
My C7000 router is causing network attached devices to intermittantly drop connection for about 30 seconds before restoring. Whenever this occurs, I check the router log and see one common thread. ...
DarrenM
Aug 11, 2017Sr. NETGEAR Moderator
Hello Damianipa
It could be a app that installed on that iphone causing all the attacks did you install anything recently on the phone?
DarrenM
- damianinpaAug 11, 2017Guide
I don't think an app is the cause. There are several threads about this on ths forum. Is anyone from Netgear monitoring these forums? This is a problem, but, not fix has been provided. One person said, the cause is malformed packet from IPV6 address being sent from the apple iphone. If that is the case, is there a way to turn off IPV6 on this router? I hope more people chime in who have this issue also.
