BertskiZPolski
Oct 22, 2023Aspirant
C7000 Issues. Event Log Included
I'm running a C7000 through Xfinity and I've been having issues the last few days with my internet. Haven't had any issues until recently and I bought the modem a couple months ago. What's happening ...
- Oct 27, 2023
Glad they got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 23, 2023Guru - Experienced User
well, you only included about a minute or two of the logs. A bit more helps.
Along with the cable connections page (shows upstream/downstream data)
