appyface
Apr 19, 2020Tutor
C7000 max lan ip reservations?
I am looking to buy the C7000 modem/router combo. What is the maximum number of LAN IP reservations (DHCP reserved IP's) that can be defined in this unit? I checked the user guide, it doesn't list ...
Apr 20, 2020Guru - Experienced User
Theoretical maybe 249. Not sure what actual would be. Maybe memory limitations. You might have to try it would and see.
How many devices do you have that need IP reservations?
appyface
Apr 20, 2020Tutor
Hi Furry, Thanks for reply. I'm not going to buy the unit until I know for sure. Many routers only allow 25 reservations. I know the Nighthawk R7000 allows 50. Hoping this allows 50 but again, I'm not going to buy it until I know for certain. Thanks.
