Co2Outbr3ak
Jun 15, 2019Aspirant
C7000 nas-100
So, we had a storm pass through on Wednesday that messed up my internet. I already took the initial troubleshooting steps and am almost certain my modem is no longer functioning as it should. My ISP (...
Co2Outbr3ak
I attached the screenshot.
I don't currently have a spare modem to test, so my next step is renting a modem from my ISP for a month to troubleshoot further.
The tech tested for moisture and corrosion. The only issue he found was the ground for the cable line outside wasn't connected, which he fixed. I think this may have caused the problem with the modem itself, but the damage is probably already done. My ISP has already tried everything on their end, so the next step I have is swapping modems to see if it fixes. Upload speed is still bouncing constantly between 1mbps and 20mbps.
Jun 15, 2019Guru - Experienced User
Did you have the logs as well?
How old is it? If its within the year warranty, you could open a support ticket with netgear.
- Co2Outbr3akJun 15, 2019Aspirant
The modem is about 14 months old. Just outside the warranty window I'm sure. I tried to register it but it says my services expire like i bought it today. Anyways, the event log and log files are in the spoiler tag.
SpoilerEVENT LOG:
1970-1-1, 00:00:38 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:43 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:28 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:29 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:29 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:36 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:37 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:49 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:50 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:02:04 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:02:05 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:02:14 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:02:15 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:02:27 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:02:33 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.0;CM-VER=3.0;
2019-6-15, 12:13:09 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.1;CM-VER=3.0;
2019-6-15, 15:54:40 Critical (3) Resetting the cable modem due to docsDevResetNow
1970-1-1, 00:00:37 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2019-6-15, 15:56:48 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.1;CM-VER=3.0;
2019-6-15, 17:23:54 Critical (3) Resetting the cable modem due to docsDevResetNow
1970-1-1, 00:00:37 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2019-6-15, 17:26:00 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.1;CM-VER=3.0;
1970-1-1, 00:00:38 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2019-6-15, 17:38:02 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.1;CM-VER=3.0;
2019-6-15, 17:42:12 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.1;CM-VER=3.0;
2019-6-15, 17:49:59 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.1;CM-VER=3.0;
1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2019-6-15, 17:55:29 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.1;CM-VER=3.0;
2019-6-15, 18:19:55 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.1;CM-VER=3.0;
2019-6-15, 18:23:46 Critical (3) Resetting the cable modem due to docsDevResetNow
2019-6-15, 18:25:55 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.1;CM-VER=3.0;
1970-1-1, 00:00:40 Notice (6) WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT
1970-1-1, 00:00:40 Notice (6) WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT
1970-1-1, 00:00:49 Notice (6) Honoring MDD; IP provisioning mode = IPv4
1970-1-1, 00:00:51 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.0;CM-VER=3.0;
2019-6-15, 18:45:49 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:3d:cf:99:8e:f8;CMTS-MAC=00:ca:e5:c8:b8:ee;CM-QOS=1.1;CM-VER=3.0;
