| Time | Priority | Description |
| 2022-9-30, 13:07:54 | Notice (6) | WiFi Interface [wl1] set to Channel 48 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2022-9-30, 13:07:53 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2022-9-30, 13:07:51 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:5) - Reason:GUI |
| 2022-9-30, 03:37:52 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:37:02 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:36:59 | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| 2022-9-30, 03:36:49 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:36:48 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:36:00 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:35:55 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:35:47 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:35:46 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:34:58 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:34:38 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:34:32 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:34:30 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:34:10 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:34:07 | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| 2022-9-30, 03:33:58 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:33:43 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:33:41 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:33:21 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:33:18 | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| 2022-9-30, 03:33:10 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:33:05 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:33:03 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:32:42 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:32:36 | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| 2022-9-30, 03:32:24 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.0;CM-VER=3.0; |
| 2022-9-30, 03:32:16 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:32:08 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:32:08 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:32:08 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:31:44 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:31:16 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:31:08 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:30:44 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:30:37 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:30:17 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
| 2022-9-30, 03:30:17 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=c8:9e:43:76:e2:b0;CMTS-MAC=00:aa:6e:c1:3a:42;CM-QOS=1.1;CM-VER=3.0; |
