hrad
Oct 15, 2016Aspirant
C7000 Not Working Correctly
Model C7000 never updated firmware and used on TWC but when tried on COX I was told: The problem we experienced was that the modem appeared to be in a loop never being able to connect to the Inte...
DarrenM
Oct 17, 2016Sr. NETGEAR Moderator
Hello Hrad
Have you tried to do a factory reset on the modem?
DarrenM
- hradOct 20, 2016Aspirant
Yes
- DarrenMOct 24, 2016Sr. NETGEAR Moderator
Hello hrad
I suggest contacting Netgear support.
http://www.netgear.com/support/contact.aspx
DarrenM
