polishkaz
Jul 24, 2016Guide
C7000 random internet disconnection, please help
Hello, I was having some slight issues with intermittent dropouts with an old modem so I purchased a new Netgear ac1900 c7000 modem router combo. The issues have persisted. I am hoping someone ...
DarrenM
Jul 26, 2016Sr. NETGEAR Moderator
Hello polishkaz
I am seeing quite a lot of T4 timeouts in your logs I would say you should contact your ISP and maybe have them come out and check the cable lines.
DarrenM
polishkaz
Nov 06, 2016Guide
Been back and forth with Cox, no issue found, multiple times, signals are all clean and within spec. They are claiming to not see as many T4 timeouts as I am. I noticed I'm running firmware1.01.18 when the netgear website says I should be running 1.01.15. What gives, anyway to get the older version to test it out? Did cox push a firmware thats screwing me?
