docsavage
Sep 17, 2020Aspirant
c7000 reboots randomly/stops working?
I have a nighthawk 1900 combo router/modem that is two years old.It randomly stops working.I have MY desktop connected via ethernet cable with no wifi activated on the desk top.The wireless is used fo...
Sep 17, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
- docsavageSep 20, 2020Aspirant
Thank you for responding,I tried the separate channels for the wifi,It still stopped the next day,I do have a splitter because I also have a land line telephone,with a modem from the isp.The netgear has the latest version of firmware,I have 400mbps down and 25 mbps up service with Spectrum.I increased the service the day before I adjusted the wifi channels.I don't know when this version of firmware was pushed,But the problems with disconnecting started about 4 months ago and would only occur occasionally,maybe twice a month and now it could be twice a week but it happens at least every week now.As soon as I reboot the router evrything works fine.Again thankss for taking the time to answer,I will look next at factory reset.
