tomter
Mar 22, 2018Aspirant
C7000 Router no longer blocks any porn! Parental setting not working. I don’t know what to
I have a Netgear C7000 cable/WiFi modem with cable service from Spectrum. I setup the Parental Controls via the Netgear Genie app. I had it set at the Moderate level. It worked perfectly about 3 mont...
vkdelta
Mar 22, 2018NETGEAR Employee Retired
what FW do you have on your device?
what website are you trying to block?
- tomterMar 23, 2018Aspirant
I typed in playboy.com as a blocked site in the Genie app and it is not blocking it. I don't know what FW is.
Oh, you mean firm ware I bet. Sorry about that. I will get that info to share with you.
- tomterMar 23, 2018AspirantFirmware version:
V1.01.29
I have blacklisted via routerlogin.net: playboy.com and pornhub.com, yet they are not being blocked. parental controls show enabled.- vkdeltaMar 25, 2018NETGEAR Employee Retired
just to confirm, are you using LIVE PARENTAL CONTROLS or BLOCK SITE feature?
BLOCK SITE will not block HTTPS domains.
If you are using LIVE PARENTAL CONTROL, Please make sure you are using OpenDNS DNS servers in the C7000 DNS GUI, and you have not changed the DNS servers on your laptops/cellphones.
