Stut2
Jul 03, 2020Aspirant
C7000 router won’t work with slingbox 500
I just installed this router and it works great with all my devices but when I hooked it up to sling box 500 it can’t find the server even though the WiFi networks is connected to the system. Can anyo...
michaelkenward
Jul 04, 2020Guru - Experienced User
Don't you think that the problem should be "slingbox 500 won’t work with C7000 router"?
After all:
How is this slingbox 500 connecting? What errors do you see?
Did you try this?
Stut2
Jul 04, 2020Aspirant
Yes you are right, I should have phrased it that way. Thanks for you help. My WiFi network is connected to the slingbox but when I look for the channels says “can’t find server”. From my iPad I can change the channel on my sling box so I know it’s connected but no channels are displayed. I know it is hooked up right because on the tv I have the box connected to all the displays work when I use the sling remote. My thoughts are it has something to do with IP address which is what I see as the culprit in others with connection issues. If you have any thoughts or suggestions would love to hear them. Thanks
- FURRYe38Jul 07, 2020Guru - Experienced User
Try the device wire connected to the modem?
Contact the mfr of the device for there help and information on getting there device connected correctly.
