Clevor
Sep 26, 2016Aspirant
C7000 slow WIFI
I am not very savvy with routers/modems so bear with me. I just purchased a C7000 and am using it with Time Warner cable. The WIFI is very slow on both netbooks I have. I have 100 MBPS internet servi...
DarrenM
Sep 29, 2016Sr. NETGEAR Moderator
Hello Clevor
Can you tell me what type of wireless card are in those devices or what version of 802.11 they have?
DarrenM
- ClevorOct 06, 2016Aspirant
I called up your tech line and they told me the slow WIFI is due to the "N" card in my two Atom processor netbooks (MSI U160 and Asus N10J). I use these netbooks to play videos on long plane flights, due to the long battery times in their day (5 hrs or so in 2008, when I bought these netbooks).
I found out that the browser makes a difference. I am running Windows 10 in both netbooks and with Edge browser, I get 30 MBPS upload with WIFI and 40 with Ethernet, but with Chrome I only get around 4-5 MBPS. However I have 100 MBPS internet service and I get 117 MBPS on my IPhone. Your tech support said the current cell phones have sophisticated wifi cards so that's why they can keep up. My netbooks are circa 2005-2008. However I thought that in general, the processor speed does not affect internet browsing?
I do have a faster laptop that I normally use however that is in transit right now in my household goods as I have moved from Japan to Hawaii. I know that laptop was smoking fast in Japan with the internet service I had, even though the fiber optic only went to my apartment building and not to each unit. Cell phone service really sucks here in Hawaii too, compared to Japan, where phone and internet service was never an issue no matter where you were in Japan.
I presume internet speed will be up to par when I get that laptop in use with the C7000 modem/router.
- DarrenMOct 13, 2016Sr. NETGEAR Moderator
Hello Clevor
That is correct about those older devices when they are connected to the wifi any other device connected to that wifi can only go as fast as 802.11N even though your newer laptop has better hardware so the best thing to do is keep your older equipment on the 2.4ghz wifi band and the new stuff on the 5ghz if possible.
DarrenM
- ClevorOct 26, 2016Aspirant
The only thing I don't understand is that my 'fast' laptop is an OCZ Whitebook which I bought around the same time in 2008. At that time it cost $2500 and was the fastest gaming laptop on Earth. That's pretty much a joke now. However it obviously came with the same 802.11a/g/n WIFI card but CPU was an Intel Core 2 Extreme Mobile QX9300 Quad Core (2.53GHz/12MB L2/1066MHz FSB). When I left Japan two months ago, it was super smooth when it came to YouTube, particularly when I upgraded to Windows 7 Pro and then Windows 10. My apartment in Japan had fiber but only to the building. Individual wiring to each apartment was still the old stuff. I never bothered to check the WIFI speed but it was plenty fast. Right now that laptop is still in my household goods shipment which won't arrive till late November. We shall see how it does, but on paper, it should have the same issues.
Believe it or not, I used to build overclocking computers from 2000-2005. I had some of the fastest RAM on Earth, top 10 worldwide (stuff like RDRAM that could run 156/4X FSB and DDR that could clock >300 fsb (rated at 133 FSB), @ 2-2-2. I had BH-5 that could do 170-180 FSB @ 2-2-2 (if you gave it enough volts), that normally was used with the ole Pentium 3 motherboards. However I lost all interest after 2005. That's why I never bothered to upgrade my computers since 2008, since I never gamed anymore.
