hlfox17
May 01, 2020Aspirant
C7000 Smaller Power Brick
The power plug is too big for the location I am trying to move my router modem to. Is there a smaller plug that will work with my C7000 Router Modem? I cannot believe in this day and age that big plu...
antinode
May 01, 2020Guru
> router modem to. [...]
Not a very detailed description of that problem. If the actual
problem is a too-crowded outlet strip, then I's get a cheap extenstion
cord (with a smaller plug).
> [...] I cannot believe in this day and age that big plugs are still a
> thing. [...]
Why not? Define "big".
The ratings should be printed on the adapter and the C7000, and
should be found in the User Manual, too. Shop around, if you want.
hlfox17
Trying to put the plug into a built in wall outlet and then put a second plug in the other socket. Problem is, once I put in this large power brick, there is not room for the other plug. I am trying to hide as much as possible so an extension cord just worsens the problem .
- antinodeMay 01, 2020Guru
> [...] I am trying to hide as much as possible so an extension cord
> just worsens the problem .Get/make a shorter extension cord? With my weak psychic powers, I
can't see any of the stuff which you're not describing very well. You
seem to have a home-improvement problem, not a modem+router problem, so
this might not be the best forum for it.Previous advice still applies.
