brsox88
Jun 03, 2019Tutor
C7000 Speed & Connectivity Issues - DoS Attacks
Hi, I am having inconsistent speeds and connectivity with my C7000 modem router. I have been dealing with this for a long time. My power levels are good. I am the only one on my wireless band channel...
Jun 04, 2019Guru - Experienced User
What wireless devices do you have?
Do a factory reset and this time don't set up a custom SSID name just yet.
After the modem is online, test the speeds with a wired PC. Then test with your wireless device. Connect to the default SSID first and check speeds. Speeds still inconsistent or consistent at this point?
After testing, set a custom SSID and PW.
Set a IP address reservation for your devices ON the router.
