oncourse
Feb 18, 2020Aspirant
C7000 stuck in IPv4 Only Mode on Charter
I recently moved with my C7000 modem/router combo that I've had for a couple years. Previously I was using it on Comcast/XFINITY with no problems at all - everything worked great. Now I live in ...
oncourse
Attached screenshot of provisioning mode issue.
If I run a test at testmyipv6.com, it shows I do not have ipv6. If I attempt to load the ipv6 only test, the page will not load.
In the ipv6 settings it shows the system delegated prefix and that's it, no other info.
Feb 18, 2020Guru - Experienced User
My inlaws have the same C7000 on charter. I remoted in quick and their's shows the same IPv4 Only when you click on the modem. I've got it setup through their Advanced----advanced setup----IPv6 in auto config mode. And it pulls the proper setup but still shows "Ipv4 only" on modem page. Running it through the ipv6 test it gets 9/10 with only charter's dns server failing.
Have you tried changing your dns server?
