oncourse
Feb 18, 2020Aspirant
C7000 stuck in IPv4 Only Mode on Charter
I recently moved with my C7000 modem/router combo that I've had for a couple years. Previously I was using it on Comcast/XFINITY with no problems at all - everything worked great. Now I live in ...
oncourse
I did indeed, have had it set to Google DNS (8.8.8.8 and 8.8.4.4) with no dice. I just tried to change it back to the default DNS just to see if anything has changed. Same test results.
Any other potential DNS to try? I know there's Cloudflare.
Results of IPV6 test posted.
vkdelta
Feb 19, 2020NETGEAR Employee Retired
there are two IP stacks on the device and they are independent of each other.
The screenshot which refers to Ipv4only provisioning means Charter has provisioned your Cable modem to IPv4 ONLY. They have intentionally done it from their provisioning systems. this is for CM Mgmt
For eRouter/WAN, there is WAN stack where user traffic is routed. You need to show Advanced page tab and also WAN connection and IPv6 connection page info.
C7000 device just get told to provision WAN on IPv4-only or Dual-stack. Charter's DHCP/DHCPv6 and config file needs to enable dual-stack. If they have not done that, you will not see dual-stack.
