BobMA2
Feb 16, 2017Aspirant
C7000 suddenly has slow internet connection speeds
I purchased the C7000 Nighthawk modem/router on 3/16/2016 as an upgrade/combination of a previous Motorola modem and N900 Netgear dual band router. The Nighthawk performed flawlessly until last week...
- Feb 24, 2017Hello DarrenM.
I did try both the software factory reset through Netgear Genie and the hardware reset by inserting a paperclip in the reset hole on the back side of the modem/router. I will contact Netgear this weekend. Thanks for your suggestions.
DarrenM
Feb 22, 2017Sr. NETGEAR Moderator
Hello BobMA2
Are you getting this slow of speeds when running speed tests over a wired connection?
DarrenM
