BobMA2's avatar
BobMA2
C7000 suddenly has slow internet connection speeds
I purchased the C7000 Nighthawk modem/router on 3/16/2016 as an upgrade/combination of a previous Motorola modem and N900 Netgear dual band router.  The Nighthawk performed flawlessly until last week...
  • BobMA2's avatar
    Feb 24, 2017
    Hello DarrenM.
    I did try both the software factory reset through Netgear Genie and the hardware reset by inserting a paperclip in the reset hole on the back side of the modem/router. I will contact Netgear this weekend. Thanks for your suggestions.
