Travelscribe
Dec 27, 2016Aspirant
C7000 supported USB Drives
I've been having difficulty adding a USB Drive to my C7000 Nighthawk - AC1900 WiFi Cable Modem Router. I started with a Seagate Backup Plus Hub 4TB External Desktop Hard Drive Storage (STEL400010...
havdaddy
Jan 02, 2017Aspirant
I have a similar problem, except that I am using a standard PC format (NTFS) of the hard drive. It initially worked but now doesn't recognize any USB device attached. I've attempted to use the same seagate drive you have plus other seagate USB drives, as well as WD. Nothing is recognized.
Travelscribe
Jan 03, 2017Aspirant
havdaddy - I just got off the phone with Netgear support and here's what I was told:
Any drive will work with the C7000, on the Macintosh with OSX. However, to get a USB drive to work with the C7000, you need to contact support for the manufacturer or the USB drive and find out the port number required to access the drive.
This is not documented anywhere and to be honest, doesn't make a lot of sense to me. After all, my drive initially worked without a port number before it stopped working!
However, I'm off to order a new drive. Hopefully this works.
- swellerMay 11, 2017Aspirant
Where do you enter the port number?
