ramclaren
Jul 26, 2021Initiate
C7000 v2 "Firmware Out of Date" on Nighthawk Ap
I have the C7000v2 WiFi Cable Modem Router and the Nighthawk app on my iPHONE. When I login to the app on the iPhone, I get the message "Firmware Out of Date" and the app will not run. I conta...
Jul 27, 2021Guru - Experienced User
Try removing the NH app and then re-install it.
Power OFF the modem for 1 minute then back ON. FW is current and nothing newer for this model modem.
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App and know how to work it better than those of us who follow this "general router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Good Luck.
ramclaren
Jul 27, 2021Initiate
Thanks FURRYe38.
I have posted my message on the Nighthawk community forum.
- antinodeJul 27, 2021Guru
> I have the C7000v2 WiFi Cable Modem Router [...]
> It is a bug in the app.
Even if the (lame) app were right, and your firmware were obsolete,
what, exactly, do you think that you could do about it?
