Jetguy
Sep 13, 2021Aspirant
c7000_v2 SSID Broadcast Issue
Hello All, I am using a Netgear AC1900 C7000v2 CableModem. When I run a windows utility that shows/detects wireless connections in my area one of the field is COMPANY. This field shows the name o...
Jetguy
Hi FURRYe38,
No matter what I do the Company name still shows. I powered the modem off for a few mins then powered back on. No-go. I enabled, disabled, renamed SSID and it still showed. I did noticed another NETGEAR company name in my list(those not broadcasting SSID like myself) just now. So maybe there is no way to prevent it. I am using the Nirsoft WiFi Info View portable utiilty: https://www.nirsoft.net/utils/wifi_information_view.html
Thanks again!
Sep 13, 2021Guru - Experienced User
So with the modem powered OFF and not back ON, does the one SSID appear still?
Can you post a screen capture of what your seeing? Use the choose file button to inlcuded your picture file.
- JetguySep 13, 2021Aspirant
With the modem turned OFF, my listing no longer shows in the list of wifi's around me. I am going by my MAC ADDRESS and with power ON its there, power OFF its not. I see numerous other wifi's around me not broadcasting SSID and others that are. In the screen shot below it shows all wifi's I am detecting(mine has the MAC blocked out purposely). With the modem OFF the screen shot would be identical except that my listing within it is no longer there. In this screen shot you can see two other wifi's that are broadcasting the Company/Manufacturer name( NETGEAR modem and a 2WIRE).
Image didn't make it. Its here. BTW I am only broadcasting/enableing 2.4Ghz wifi.
- FURRYe38Sep 14, 2021Guru - Experienced User
Thats something that can't be disabled. Just because other wifi signals are not showing the Company name doesn't mean they are not being broadcast. I presume the app controls this and can only give the company name if you were connected to there wifi signal then the company name maybe seen on that app. Something to ask the mfr of this app about. The app maybe detect the router mfr and then filling it in under the company name column. Something NG doesn't control.
- JetguySep 14, 2021Aspirant
I dunno. Its just weird to me. But I do thank you for your input and thoughs.:smileyhappy:
