Jetguy
Sep 13, 2021Aspirant
c7000_v2 SSID Broadcast Issue
Hello All, I am using a Netgear AC1900 C7000v2 CableModem. When I run a windows utility that shows/detects wireless connections in my area one of the field is COMPANY. This field shows the name o...
Sep 13, 2021Guru - Experienced User
So with the modem powered OFF and not back ON, does the one SSID appear still?
Can you post a screen capture of what your seeing? Use the choose file button to inlcuded your picture file.
Jetguy
Sep 14, 2021Aspirant
With the modem turned OFF, my listing no longer shows in the list of wifi's around me. I am going by my MAC ADDRESS and with power ON its there, power OFF its not. I see numerous other wifi's around me not broadcasting SSID and others that are. In the screen shot below it shows all wifi's I am detecting(mine has the MAC blocked out purposely). With the modem OFF the screen shot would be identical except that my listing within it is no longer there. In this screen shot you can see two other wifi's that are broadcasting the Company/Manufacturer name( NETGEAR modem and a 2WIRE).
