Jetguy
Sep 13, 2021Aspirant
c7000_v2 SSID Broadcast Issue
Hello All, I am using a Netgear AC1900 C7000v2 CableModem. When I run a windows utility that shows/detects wireless connections in my area one of the field is COMPANY. This field shows the name o...
Sep 13, 2021Guru - Experienced User
So with the modem powered OFF and not back ON, does the one SSID appear still?
Can you post a screen capture of what your seeing? Use the choose file button to inlcuded your picture file.
Jetguy
Sep 14, 2021Aspirant
Image didn't make it. Its here. BTW I am only broadcasting/enableing 2.4Ghz wifi.
- FURRYe38Sep 14, 2021Guru - Experienced User
Thats something that can't be disabled. Just because other wifi signals are not showing the Company name doesn't mean they are not being broadcast. I presume the app controls this and can only give the company name if you were connected to there wifi signal then the company name maybe seen on that app. Something to ask the mfr of this app about. The app maybe detect the router mfr and then filling it in under the company name column. Something NG doesn't control.
