yepphers's avatar
yepphers
C7000 v2 switching between 2.4ghz and 5ghz wifi
I can't find anywhere a "smart connect" box on the dashboard settings. Wondering if this modem router combo automatically selects the best connection speed? I live in a condo and everyone has a wifi connection. I thought with a dual band router that it would select the best connection based on traffic in my building. Is this correct or do I manually switch between 2.4 and 5G?
1 Reply
  • FURRYe38's avatar
    Manually switich. I don't believe the C series modems supports Smart Connect.
