Sunnyside5
Jun 24, 2019Tutor
C7000 V2 will not find HP 4630 Printer
Router will not find the HP 4630 printer connected through the USB port. My second computer on-line found the printer but states off-line. Anyone know what Printers are supported or work arouds?
- Jun 25, 2019If you mark the correct answer as solved, it makes it easier for the next person with this issue. Glad you got it working!
Jun 24, 2019Guru - Experienced User
Have you tried the readyshare utility?
https://kb.netgear.com/19593/How-do-I-download-and-install-the-ReadySHARE-Printer-utility
antinode
Jun 24, 2019Guru
> port. [...]
That printer has a wireless-network interface, does it not? Why use
a USB connection to anything with it, especially anything involving
Netgear-supplied software?
https://support.hp.com/us-en/product/x/5305049/model/5305050
http://h10032.www1.hp.com/ctg/Manual/c03909822
- Sunnyside5Jun 25, 2019Tutor
Unfortunately my computers are not wireless, they are desktop with LAN connectivity.
- plemansJun 25, 2019Guru - Experienced User
but the C7000 is wireless and so is the printer. You could connect it over wireless, set it with a static or reserved IP address, and all your devices should be able to print to it if they're on your network. Both windows and mac can print to a wirelessly connected printer.
I am not that familiar with Static and reserve IP settings. I will read up on that option and give it a try.
