Sunnyside5
Jun 24, 2019Tutor
C7000 V2 will not find HP 4630 Printer
Router will not find the HP 4630 printer connected through the USB port. My second computer on-line found the printer but states off-line. Anyone know what Printers are supported or work arouds?
- Jun 25, 2019If you mark the correct answer as solved, it makes it easier for the next person with this issue. Glad you got it working!
Jun 24, 2019Guru - Experienced User
Have you tried the readyshare utility?
https://kb.netgear.com/19593/How-do-I-download-and-install-the-ReadySHARE-Printer-utility
Sunnyside5
Jun 25, 2019Tutor
I have tried ReadyShare on both computers, one does not show any attached hardware and the other find the printer as active, but whenI try printing it shows the printer off-line. Everything I see says it is on-line except for Ready Share.
I am thinking of adding an ethernet converter to the USB cable and connecting the printer to the Ethernet Port and not use ReadyShare. If that does not work, I will take the Netgear Router/modem back. When I used my Dlink router with a Linksys Modem it all worked fine except for frequent drops which required rebooting, but the printer worked great.
- plemansJun 25, 2019Guru - Experienced User
You don't have to set it with a static IP address but whenever the router gives the printer a new IP address, you'd need to reinstall. Setting it with static or reserved IP fixes that.
Heres how to do a printer install in windows 10.
https://www.windowscentral.com/how-connect-your-wireless-printer-windows-10
Here's how you set a reserved address on a netgear. Its fairly simple to do.
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
- Sunnyside5Jun 25, 2019Tutor
Thank you very much for walking me through these steps. I learned a lot and I also now have a working printer.
Again, thank you.
- plemansJun 25, 2019Guru - Experienced UserIf you mark the correct answer as solved, it makes it easier for the next person with this issue. Glad you got it working!
