Sunnyside5
Jun 25, 2019Tutor
C7000 V2 will not find HP 4630 Printer
Router will not find the HP 4630 printer connected through the USB port. My second computer on-line found the printer but states off-line. Anyone know what Printers are supported or work arouds?
- Jun 25, 2019If you mark the correct answer as solved, it makes it easier for the next person with this issue. Glad you got it working!
Jun 25, 2019Guru - Experienced User
but the C7000 is wireless and so is the printer. You could connect it over wireless, set it with a static or reserved IP address, and all your devices should be able to print to it if they're on your network. Both windows and mac can print to a wirelessly connected printer.
Sunnyside5
Jun 25, 2019Tutor
I am not that familiar with Static and reserve IP settings. I will read up on that option and give it a try.
