Sunnyside5
Jun 24, 2019Tutor
C7000 V2 will not find HP 4630 Printer
Router will not find the HP 4630 printer connected through the USB port. My second computer on-line found the printer but states off-line. Anyone know what Printers are supported or work arouds?
- Jun 25, 2019If you mark the correct answer as solved, it makes it easier for the next person with this issue. Glad you got it working!
antinode
Jun 25, 2019Guru
> Unfortunately my computers are not wireless, they are desktop with LAN
> connectivity.
Shouldn't matter. Network-connected should be network-connected,
unless defective Netgear router firmware erroneously isolates wired
devices from wireless devices.
> [...] set it with a static or reserved IP address, [...]
Why?
> [...] Both windows and mac can print to a wirelessly connected
> printer.
I suspect that they can also find one without it having a fixed IP
address. See below.
> I have tried ReadyShare on both computers, [...]
A network-connected printer does not use ReadySHARE. A printer which
is USB-connected to the router can use ReadySHARE. Which is best
avoided, if your printer can be network-connected.
> I am thinking of adding an ethernet converter to the USB cable and
> connecting the printer to the Ethernet Port and not use ReadyShare. If
> that does not work, [...]
It wouldn't, but you don't need to do anything like that.
> I am not that familiar with Static and reserve IP settings.
I claim that you don't need to deal with that. It'd be harmless, but
unnecessary.
> You don't have to set it with a static IP address but whenever the
> router gives the printer a new IP address, you'd need to reinstall.
> Setting it with static or reserved IP fixes that.
I doubt it.
https://en.wikipedia.org/wiki/Bonjour_(software)
> next person with this issue. [...]
Give or take the misinformation.
Jun 25, 2019Guru - Experienced User
antinode I get that I probably don't know as much about this as you do. Happy to see you correct me.
Sunnyside5 In my experience, whenever a printer changes IP addresses and its connected using Windows, you have to reassociate the printer driver with the new IP address or it doesn't work, it'll show as offline. The printer getting a new IP address could be from a random reboot, power fluctuation, or just you rebooting the router.
The printer is easy to reassociate/reinstall but then you're doing it every time the IP address changes. Its a PITA. Or you can just set a address reservation. From the sound of it, you were able to accomplish this. glad to see you had success in getting it working. Sorry you had to read the prior snark.
