shdwdm's avatar
shdwdm
C7000 v2
I believe there is a software issue that is slowing down my modem. Most time I recieve less then half of speed I a get from my provider
  • plemans's avatar
    What speeds do you pay for?
    What speeds do you get hardwired into it?
    How are you testing speeds? (device, website, etc)
    Do you have a screen snip of the cable connections page and the event logs? that helps us check the signal.
