JessAOII
Mar 26, 2017Aspirant
C7000 won't connect to NetGear Genie to allow Parental Controls
I can connect through the web to our modem/router but will not connect to Netgear Genie program on my laptop or on my android phone.
JessAOII
Mar 29, 2017Aspirant
It just tells me that my password is wrong but I use the exact same password when I access it through it IP address.
DarrenM
Mar 30, 2017Sr. NETGEAR Moderator
Hello JessAoll
Try to change the password on the routers login or even go back to default one password to see if that will let you in.
DarrenM
