jackbmc
Jun 15, 2017Tutor
C7000 Won't Update via TW/Spectrum
I posted here 3-4 weeks ago concerning my C7000 losing internet signal and wifi. It was determined that the problem COULD be the out of date Firmware on the 10 month old device. The Firmware that ca...
jackbmc
Jun 26, 2017Tutor
For the most part I agree with your post....certainly the conclusion that we are S.O.L. However, I don't believe the TW tech person I spoke with about a month ago now was untruthful in saying they had made attempts to update the Firmware and they had failed. He made multiple attempts while I had him on the line...and each one would show up on my event log as T3 or T4 timeouts and other critical errors. It was a copy of that log that resulted in Netgear sending me a replacement C7000. However, as mentioned the replacement had exactly the same out of date firmware! I DO agree that TW/Spectrum no longer updates a product they do not sell...and that is a recent decision. Since June 16 there have been NO events on my log that reflects errors and/or timeouts so I think they have, indeed, quite trying. The fact that they quit trying has improved my original problem which was signal drop outs on the C7000. The tech had told me that when the Firmware is updated you can and usually do lose connection afterwards until the modem reboots. I believe, but don't know, that each attempt ultimately took me off-line and there were MANY attempts....at all hours. So, my problem with drop outs is minimal even though my firmware is out of date. I have favored Netgear products for years and rarely had a problem. I started in the old days when the router had a life time warranty. Now the life of it is unpredictable but when it is over...it's over. I would not likely buy another Netgear product as a result but right now I don't know which product I would buy.
Thanks to all for replying.
jackbmc
William10a
Jun 26, 2017Master
I feel sorry for this world if all the produces we use go this way as even the government has out dated computers systems running today which many think unreasonable but you have to remember one in the end it comes down to money and some of programs that they need do not run very well on a modern computer.
What would the cost be to convert all the different forms of computer data to standardize format today and how long.
Since the firmware is not released to the end users the one way one could possible update the firmware is also closed off via a serial cable like you would a router the modem has a cpu and memory like a router and should have a serial port points on its circuit board which is a dirt trick.
