dupy94
Jul 25, 2016Follower
C7000
I just purchased this combination WIFI modem/router. I cannot figure out why the WPS light will not stay illuminated. It worked fine on my previos router, WNDR4500v2.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello dupy94
If you have the wifi on/off button on off the WPS button will be off you may also want to check the WPS settings in ADVANCED > Advanced Setup > Wireless Settings.
DarrenM
