Viper300
Dec 05, 2019Aspirant
C7000
I am a complete novice, so bear with me. We have Xfinity GB service and we are thinking of purchasing the CM1150V for the cable modem but we then want to use our already purchased C7000 as the router portion. Will this work or do we need a new wireless router only that isnt a cable modem router?
Make sense?
> [...] use our already purchased C7000 as the router portion. [...]
Because it lacks a WAN/Internet Ethernet port, I see no way to use a
C7000 as a normal router. (It should be possible to configure a C7000
as a wireless access point, but that wouldn't give you a router.)> [...] do we need a new wireless router only that isnt a cable modem
> router?I believe so.
Can't you use the C7000 as your modem on Xfinity? Is it too slow?
What does Xfinity says about its compatibility?
- Viper300Aspirant
The C7000 will work as the cable modem and router but one I'd have to lowere service plan to 500mb which I'm ok doing, but then we lose voice. I'm looking into what penalities Id incur by cancelling the xfinity home and infinity voice and just haveing cable and internet at 500mb and maybe channel lineup. Then get Voip seperate.
That way the C7000 will be fine. My son in law said he hooked it up at their house and it doubled the wifi speed. But problem is they didnt have voice, we do. Speeds acheived are only fast if the device has capability so I dont have new enough items to get super fast that 500mb wouldnt be fast enough
but to your question, the C7000 cannot be used as stand alone router with a different cable modem on top of it. I wanted to use it as router function only but......
That explains things. Your first message didn't mention voice explicitly, although I should have guessed from the reference to the CM1150V.
I am not familiar with voice technology. I do know that 500 Mbps would be fast enough for voice and most other things.
I have no idea which Netgear boxes can do voice, beyond the CM1150V and the slightly older CM500V. (Those things often go under the "gateway" label with ither brands.) There are also modem/routers that do voice, the C7100V for example.
However, in general, experienced users like to have separate modems and routers. I was just thinking "money". After all the C7000 isn't that old.
Having two separate devices means that you have a bigger choice and more control over the kit. As you have found, you have not way of updating the firmware on the C7000. But if you put a router behind a cable modem, you get not only a bigger choice of features, you get something that you can update should new features turn up.
Not my question. I don't know a lot about cable modems. The technology is not widely used here in the UK. But I agree that it is hard to turn something into a router without a WAN port on the thing.
